Power Steering in 90 Minutes!
   / Power Steering in 90 Minutes! #91
All the Hondas I've owned have them, the pump is nice and small so should fit into small spaces. Finding a V-belt one would be ideal but I assume the pulley can be swapped.
   / Power Steering in 90 Minutes! #92
That's why I suggested the Volvo ones, they are pretty much the same size, use a v-belt pulley and have a remote remote reservoir.
Aaron Z
   / Power Steering in 90 Minutes! #94
Actually most all the Volvo units (pumps) are Saginaw and are much the same as the General Motors units.
The differences are pretty much rotation (serpentine vs. V-belt) and relief valve pressure and pump volume. They make around 1400 psi.
Good luck, Fred
   / Power Steering in 90 Minutes! #97
I bought a kit for a Ford and adapted it to my Kubota L285, now my 3 point don't work. Any ideas?
   / Power Steering in 90 Minutes! #98
Pictures of the valve and hoses are needed. Sounds like you mixed up the Tank and Power Beyond lines.
Aaron Z
   / Power Steering in 90 Minutes! #99
Would need to see how it's plumbed. Hydraulic fluid takes the path of least restriction.
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2014 Chevrolet Impala Limited Sedan (A55853)
2014 Chevrolet...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
