Power steering hose re-route???
   / Power steering hose re-route??? #1
Toby873
myakka city, Florida
Branson 4720i
I have found my steering problem. Leaking hose that goes to the top of the front axle. This hose is the only one that is routed below the main frame and engine block. It is obvious that it was punctured by driving over something. If I buy a longer hose is there any problems with re-routing this hose a little bit? Would the extra length and a few more slight turns cause problems with fluid flow/compression/drag or whatever? Toby
   / Power steering hose re-route??? #2
I don't see anything wrong with doing that.
   / Power steering hose re-route??? #3
Yeah, like Wallace said the pressure is going to build up in the system, and in the grand scheme of things the little extra length of the hose the system won't even notice.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2017 TAKEUCHI TB290 EXCAVATOR (A51246)
2017 TAKEUCHI...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
JOHN DEERE 54D LOT NUMBER 148 (A53084)
JOHN DEERE 54D LOT...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
