Power Steering Help
/ Power Steering Help #41
Sounds like something is screwed up in your steering motor. It should take the same number of turns for a left or right with no pump power since the steering motor is generating the pressure to move the cylinder. You can confirm this by lifting the front end with the loader and trying the steering with the engine off.
I'd still call Tommy.
/ Power Steering Help #42
-More turns needed to turn the wheel to the left than the right.(No weight on the front end via lifting with the FEL)
-I hear noise coming from the pump when I hit the stops in both directions.
-Lifting the front end is complicating the issue. What happens when both front tires are solidly on the ground?
-Normal
-I'm not ready to point any fingers at the steering controller yet. I've been on these forums for years, and don't recall one single occasion of steering controller failure.
-reserving judgment on pump failure, as I'm still unclear about symptoms in a normal operating environment.
-I'd like to revisit the rubber hoses. Remove both, put the right where the left was and the left where the right was. See if your problem now shifts to right turns.
//greg//
Nothing happens when the wheels are on the ground. The wheels only move with what little pressure I can generate with the steering wheel. You can hear a little noise from the pump just like the noise when the tires are off the ground and I hit the stops. There aren't any leaks in the hydraulic lines.
I counted the amount of turns with engine running and front end of the ground. From wheels straight It took 1 1/8 turns to the right until it stopped. From wheels straight it took 2.5 turns to right. When the weight is on the ground and the fel is in the air the only turning I get is from me wrestling with the steering wheel.
/ Power Steering Help #45
At this point it seems like I would look at the pressure relief first then the pump itself.
Chris
Does the pressure relief valve happen to be the one with the stack of washers inside the cap where the spring is at? The cap is next to the pressure line.
/ Power Steering Help #47
Sounds like that is it. I would take it apart very carefully and clean it up then put it back together and give it a try. It may just have a piece of debris holding it open slightly and now not allowing it to develop pressure.
Chris
/ Power Steering Help #48
You can try to play with pressure relief, it won't hurt anything at this point. More likely the pump is shot. The number of turns problem however, is likely unrelated. I'd say the cylinder and/or drag link probably need(s) to be repositioned/adjusted.
//greg//
I'm going to order parts today that I need so i will just go ahead and order the pump too. I should have them Monday from homier/ farm pro. I can usually get parts next day from homier with them being in indiana and me being in coldwater, mi
I'm going to order parts today that I need so i will just go ahead and order the pump too. I should have them Monday from homier/ farm pro. I can usually get parts next day from homier with them being in indiana and me being in coldwater, mi.
/ Power Steering Help #51
The fluid doesn't come out under any noticeable pressure difference between the engine running and not. The fluid does move. It went down when I had to get fluid back into the cylinder.
/ Power Steering Help #53
Chiming in here a little late. I had the exact same thing happen to me. It would steer fine in one direction and very hard in the other. Turns out it was the pressure relief valve built into the power steering pump. Simple adjustment. There is a Socket head cap screw cap on the pump, remove that cap then tighten the internal screw clockwise to put more pressure on the relief spring. If that does not work then you need a new pump.
The reason it is easier to steer in one direction and not the other has nothing to do with a bad cylinder seal. Hydraulic cylinders have a shaft on one side and not the other. A cylinder can push with more force with lower input pressure than it takes to pull a load because the rod in the cylinder reduces the surface area the fluid can push against. Simple logic tells me there is low pressure on the steering cylinder.
Attached are some pictures of the pump and the adjustment.....
Larry
I ended up cancelling my order with Farm Pro and got all of my parts from affordable tractor sales. I put the new pump on and the steering came back to life. I worked for a couple of hours yesterday on clearing out brush growing out into my pond. I did have to take the new pump apart and switch it around so that it would work with the TY395I engine.:thumbsup: I'm so excited that I can get back to work.
/ Power Steering Help #55
Thanks for the update, Jimmy! Glad to hear you got it working again. :thumbsup:
Rich
Flex King KM 7 Section V Plow (A63688)
Flex King KM 7...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2001 Freightliner Allegro Bus Class A Motorhome (A61574)
2001 Freightliner...
2017 Ford Expedition SUV (A61574)
2017 Ford...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
