Power Steering Help
/ Power Steering Help #31
That stinks. If you have seperate pumps like you said that may be the next logical place. The only other possible issue could be in the steering box itself.
I think you need the help of someone smarter than me at this point so I will leave it up to the guys with more experience.
Chris
Okay. What should I do now?
Things to note from previous posts
-The current power steering pump has a stack of washers inside the one cap where the spring is for the valve in there.
-Initially the power steering worked but it would continuosly turn to the left after the wheels had stopped moving.
New Things I noticed
-with the weight off the front end using the FEL. It takes a heck of a lot more turns of the steering wheel when going left then it does going right. I did not actualy count the amount of turns it took though.
If it's the pump
I'm trying to find the correct power steering pump. The parts manual that came with my tractor doesn't list a part number for the power steering pump. I got a newer part's manual from Affordable tractor sales for the 300 series. It lists part 62 in the power steering diagram as a CBT-E306. I found a CBT1-E306HL0624 on jmparts.com. That same number has a different image on parts.FarmProTractors.com. The CBN-E310 on parts.farmprotractors.com looks like it's the correct one. I'm confused. I need the one that looks like the image in the CBT1-E306 from jmparts and like the CBN-E310 from farmprotractors.com Can someone confirm what the correct part number is?
/ Power Steering Help #34
Just realized I've lost track that the tractor under discussion is a 2430; a two-pump tractor. So ignore my previous about a priority valve - there won't be one. The numerical value assigned to Chinese hydraulic pumps is the flow rating. 306 is a lower capacity pump (in ml/sec) than a 310, which is lower than a 316, et cetera. Since the pump handles steering only, you don't really need much more than a 306. The fact it may look different on the internet, is likely due to some websites using generic photos.
Take a look at the rubber steering hoses. One of them controls turning to the right, the other controls turning to the left. Start the tractor, set the revs up to about 900, turn the steering wheel in both directions. Watch to see if any fluid drips (and where) OR if one hose jumps more than the other.
//greg//
greg_g said:
The numerical value assigned is the pump flow rating. 306 is a lower capacity (in ml/sec) than a 310. You don't really need much more than a 306 if it's strictly for steering. But I've lost track here, is yours a one-pump or two-pump hydraulic system?
//greg//
Two pump system.
/ Power Steering Help #36
I realized that too late, and edited my post while you were responding
//greg//
//greg//
The hoses don't do much of anything. When I hit the stops in either direction I can hear what sounds the be the pump trying to do something. That's all it does.
/ Power Steering Help #38
If you hear a groaning noise when you hit the stop when turning, that sounds like your pump is straining against the relief valve - i.e., it is pumping, but either not sufficient volume of fluid to do the job or things are bypassing somewhere else in the system, like possibly the steering motor itself. No offense, but is the reservoir in front of the radiator full of fluid? Sometimes the simplest things are the ones we forget.
You probably could benefit from using a pressure gauge that you could insert into the system at various places to diagnose this better. If this was my tractor I'd be calling Tommy at Affordable Tractor and getting his advice.
Good luck with it!
Rich
/ Power Steering Help #39
That's normal. You're hearing the pressure relief valve protecting the pump when the front wheels hit their respective mechanical stops. But now I'm confused. Originally you said the steering wheel keeps turning in one direction, but now you say it hits stops in both directions.
I think it might be wise to start over with a fresh description of the current problem.
//greg//
Okay. Here goes with the description of the problem now. The tractor is a 2003 Farm Pro 2430 (JM 304).
What I noticed before the steering started to act up
-I was never able to hit a stop going left but able to going right
Before it completely quit
-I had steering left but nothing to the right after the wheels were straight
It then just finally quit all together. After it quit all together I was able to then hit a stop in both directions. The only steering I have is whatever pressure I can generate with the steering wheel.
I replaced the seals in the steering cylinder yesterday. That didn't solve the problem. That rules out internal bypass of the cylinder. The old seals weren't torn or anything like that either.
Now
-More turns needed to turn the wheel to the left than the right.(No weight on the front end via lifting with the FEL)
-I hear noise coming from the pump when I hit the stops in both directions.
The resevoir is full of fluid and the lines feel as if they are warming up with the fluid passing through it. I am using AW32 for the fluid.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
Rhino DB150 (A57148)
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
16001 (A55853)
16001 (A55853)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
