Power steering for a 1650 revisit - update/revision
   / Power steering for a 1650 revisit - update/revision #1
pacer1980
Greenwood La USA
Kubota BX25D Mitsubishi D1650
I recently had posted about adapting/adding electric power assist steering (EPAS) to my 1650 with FEL (cause it - and other similar models - is a bear to steer!) But there were a few things that I wasnt especially pleased with --- so, I backed up and done a 're-fit'
The EPAS systems are VERY common on the newer cars and I had used one off an 03-07 Saturn Vue using an after market module to make it work. I first tried this on a Wheel Horse garden tractor and it turned out rather well so I decided to try it on the Mitsu -- and, it did work ... for a while. The electrics were just too finiky.
Since starting these projects I had found out that many - if not most, Japanese cars with EPAS would function without the after market module. This opened up a large variety of sizes/shapes/ and mostly power to choose from. From research I found the larger cars had the more robust motors which I figured was a factor in a rather heavy 4wd with FEL loaded! So I opted for a unit from a '14 Hyundai Sonata for my next venture. Pretty much had to start from scratch to do the retrofit but I was able to also work it in between the steer wheel and steer box. Mind you, this is not a project for the faint of heart! I have many hours in fitting/adapting/bracing/cutting/welding, etc etc to get the end result (thankfully I'm retired so time isnt a problem) It was/is sure worth it tho, I went out and got a full bucket load of dirt and it handled it with ease! Money wise its not bad, from my experience and reading of others, these units sell in the $50 range from the u-pull-it places.
Took a couple better pictures this time .....
   / Power steering for a 1650 revisit - update/revision #2
What a great idea! Thanks for the write up and pics.
   / Power steering for a 1650 revisit - update/revision #3
Slick!
   / Power steering for a 1650 revisit - update/revision #4
Dan could this be done to the satoh s370d beaver. I could not find your pictures
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2015 John Deere 7700A Precision Cut 100in Reel Commercial Mower (A52377)
2015 John Deere...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
2011John Deere 244J (A47477)
2011John Deere...
