power steering fluid overheat
   / power steering fluid overheat #11
Typically you can feel it on the steering wheel. While sitting stationary or driving slowly turn the wheel to the stop. You should feel a change in resistance just shortly before the stop and holding it against the stop. This change is when you are starting to force oil over the relief valve.
Very good info, and probably a finger squarely on the cause of the problem given the correct fluid and recent filter has been verified.
   / power steering fluid overheat #12
You changed the power steering filter? Did you add New Holland 134 hydraulic oil?
HI RICKB; can anyone help me... i have a mahindra 4500 2wd, and for the second time i have replaced my tractor HSU(steering box under the steering wheel), twice and have a new HSU and still having the same problem. As I run my tractor cutting,, my steering wheel began to get stiffer turning,, and the wheel can turn around and around and the front tires is barely turning or not turning at all. The first time i removed the HSU, the HSU was leaking from the top of the HSU, and leaking under my steering wheel. I had the HSU top seal replaced, I reinstalled the HSU myself, and i drove the tractor, for some time, and I began to notice the tractor will not make sharp turns, but will make wide turns. Again I start hearing a boiling or frying noise, it sound like it coming from the HSU. For some reason my power steering fluid reservoir box is getting supper hot. From my internet search hot steering fluid will cause steering problems. Can anyone inform me what is making my power steering reservoir or power steering fluid to overheat. When i let the tractor sit over night or a day or two, and can get on the tractor and steer right and left sharp for about 10 mins, and again the steering gets stiffer and later will not turn the front wheels at all.I also feel a little hit/knock in the steering wheel before this happen... Please someone give me some advice.......
   / power steering fluid overheat #13
DJP.: You'll get better response from a new thread with the problem and tractor in the title.
I would first check the steering by disconnecting the cylinder and jacking the front to take the weight off. Perhaps something is jamming it. Second, while the cylinder is disconnected, run the engine and check its operation.
I suspect since you have a new HSU, either the steering is over loaded and relieving (heating the fluid) or the cylinder is leaking internally (heating the fluid)
   / power steering fluid overheat #14
In the semi truck world, some trucks have a power steering cooler installed while most of them do without. Most likely you can find those in a Volvo.
There could be a solution for overheating.
I don't know how they are plumbed in the system.
   / power steering fluid overheat #15
If this is happening this much, the tractor world should go to electric steering like is in the majority of vehicles now being produced.
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
METAL STORAGE CABINET (A58374)
METAL STORAGE...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
