Power Steering fluid level
   / Power Steering fluid level #1
jdharris5
Pittsburg, Kansas
Ford 3000, IH284
I recently purchased a Ford 3000 with front loader. It has power steering. I have been noticing fluid leaking from the power steering reservoir. After using the tractor for a couple of hours I checked the fluid level. It was somewhat low so I added fluid to bring it up to the mark on the reservoir cap. Then I put the tractor in the barn. The next morning fluid was obviously leaking from the reservoir. I took the cap off of the reservoir and the fluid was up to the very top of the reservoir as if I had overfilled the reservoir. Any suggestions as to what I did wrong?
JD
   / Power Steering fluid level #2
first.. have you checked the filter anytime soon.. if not I would.
next.. see if the oil is foaming.
post back
Thanks, I'm away from home for a few days, but, I haven't checked the filter but I will as soon as I get back.
   / Power Steering fluid level #4
unless you have changed it.. you may fid it may be the original one.. :)
if oil is cloudy.. drain it as well.
   / Power Steering fluid level #5
Did you fill it with the tractor running?
No, tractor had been off for 5 min or so before I checked the level and filled the reservoir.
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2016 Toro Workman HD-X 4WD Diesel Utility Cart (A59228)
2016 Toro Workman...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
HUSQVARNA RIDING...
KBH 25T Tender (A56438)
KBH 25T Tender...
