Power Steering fluid level
   / Power Steering fluid level #1
jdharris5
Pittsburg, Kansas
Ford 3000, IH284
I recently purchased a Ford 3000 with front loader. It has power steering. I have been noticing fluid leaking from the power steering reservoir. After using the tractor for a couple of hours I checked the fluid level. It was somewhat low so I added fluid to bring it up to the mark on the reservoir cap. Then I put the tractor in the barn. The next morning fluid was obviously leaking from the reservoir. I took the cap off of the reservoir and the fluid was up to the very top of the reservoir as if I had overfilled the reservoir. Any suggestions as to what I did wrong?
JD
   / Power Steering fluid level #2
first.. have you checked the filter anytime soon.. if not I would.
next.. see if the oil is foaming.
post back
Thanks, I'm away from home for a few days, but, I haven't checked the filter but I will as soon as I get back.
   / Power Steering fluid level #4
unless you have changed it.. you may fid it may be the original one.. :)
if oil is cloudy.. drain it as well.
   / Power Steering fluid level #5
Did you fill it with the tractor running?
No, tractor had been off for 5 min or so before I checked the level and filled the reservoir.
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
2000 Ford F-650 TMA Attenuator Truck (A50323)
2000 Ford F-650...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
2002 International 9200i Truck (A52128)
2002 International...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
