Power Steering Fluid - JD770
   / Power Steering Fluid - JD770 #1
JeffSpencer
Bronze Member
North Carolina
4200 HST
Hey guys,
I'm trying to help a friend of mine, who is the new owner of a used JD770. He says the power steering is a bit jerky and is trying to find out where to add power steering fluid. He lives about 4 hours away from me, so I can't look at the tractor. My initial thoughts are, it's all hydraulic.. one fill point.
I have a 1999 4200, his is a 1995 790.
Anyone know if this is a separate system,.. or all hydraulic? Where does he add power steering fluid?
Thanks -Jeff
   / Power Steering Fluid - JD770 #3
On the 770 it's a common oil sump. Two pumps one for the steering ,one for everything else. The dipstick is on the back of the tractor by the 3 point top link,fill is above it . The power steering option also added a spin-on filter in front of the left rear tire. Thier is also a strainer in the back axle.I know with mine ,if I don't run the John Deere Hy Guard Low-vis oil it whines from the pumps.
   / Power Steering Fluid - JD770 #4
Since your friend is a new owner of the JD 77o, I suggest he change hydraulic fluid, filter and clean the sump screen. Good to start fresh on an unknown machine.
DeWalt Grinder (A50860)
DeWalt Grinder...
Trailer Mounted Light Plant (A50860)
Trailer Mounted...
2021 Spartan SRT-XD Zero Turn Mower (A50860)
2021 Spartan...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2016 Ford F-550 4x4 12FT. Landscape Dump Truck (A48081)
2016 Ford F-550...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
