Power steering fluid coming out reservoir, help!
   / Power steering fluid coming out reservoir, help! #1
johnking
greenville sc
1965 Massey 135
I just bought a ford 3000 with add on anadolu PS unit. It ran fine for 10 hours and then PS fluid started coming out of a hole in the cap(which I believe is a spray paint can top). I removed the reservoir today and found that the filter has catastrophically failed(top separated form the bottom). I am not a PS guy so I am using my limited knowledge base. This small cylinder shaped filter has a solid metal top and screen forming the circumference. I am assuming that this acts as a baffle the slow agitated PS(ATF) fluid and thus this is why fluid is coming out of the little overflow hole. Am I on the right track? If I am. I need to find a substitute for this filter due to the age and make of the PS unit I think it will be next to impossible. If anyone has a substitute part # or source please let me know. The filter screws onto the incoming oil fitting. I am thinking I can get some screen and putting it in the reservoir or get a elbow plumbing fitting but I am really at a loss, please help.!
Anadolu parts are ungoogleable. I have emailed the company. I think I might be able to rig a close substitute out of a foot valve from the plumbing section at lowes.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A55852)
Pallet of...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2014 Ford F-150...
