Power Steering Filter for the Kama TS254C
   / Power Steering Filter for the Kama TS254C #1
astr
Michigan
Kama TS254C
Finally changed all of fluids on my tractor. whey!!! The gear lube change was the most challenging - seven different cases that need to be changed seperately: front differential, 2x front outboard gear boxes, transfer case, transmision, 2x rear outboard final drives.
When changing the power steering fluid, I noticed that the PS reservoir contained a filter element that looked more like a real filter rather than just a screen. It was easly removed and washed but I would like to find a replacement. Does anyone have a cross reference to a US replacement?
   / Power Steering Filter for the Kama TS254C #2
We stock the filter, you should not need to change it often as there is usually very little if any debris generated by the power steering system.
   / Power Steering Filter for the Kama TS254C #3
i need a front left ball joint for the ts254c can you help
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
18 Front Suitcase Weights with Brackets (A53472)
18 Front Suitcase...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
