Power Steering Filter for the Kama TS254C
   / Power Steering Filter for the Kama TS254C #1
astr
Michigan
Kama TS254C
Finally changed all of fluids on my tractor. whey!!! The gear lube change was the most challenging - seven different cases that need to be changed seperately: front differential, 2x front outboard gear boxes, transfer case, transmision, 2x rear outboard final drives.
When changing the power steering fluid, I noticed that the PS reservoir contained a filter element that looked more like a real filter rather than just a screen. It was easly removed and washed but I would like to find a replacement. Does anyone have a cross reference to a US replacement?
   / Power Steering Filter for the Kama TS254C #2
We stock the filter, you should not need to change it often as there is usually very little if any debris generated by the power steering system.
   / Power Steering Filter for the Kama TS254C #3
i need a front left ball joint for the ts254c can you help
(3) STEEL CARTS (A51248)
(3) STEEL CARTS...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2018 CATERPILLAR 301.7D EXCAVATOR (A51246)
2018 CATERPILLAR...
