OP
jimmer2880
Platinum Member
Yes, that is correct.DRL said:Jimmer,
Great project. Thanks for all the pixs, great learning tools.
Was studying your hydraulic layout and need some help. In the upper right, blue "hard line from pump", pressure side of pump? Lower left, "transmission plug", return to tank? Am I correct?
DRL said:If so are the "P"(pressure) and "T"(tank) ports on the steering valve switched or am I missing something?
I would think that "P" meant Pressure and "T" meant Tank. However, after consulting the hydraulic schematic, and with the guy who sold the unit to me, the "P" actually goes to the Tank, and the "T" is the Pressure to the pump. It doesn't make any sense to me though. Hopefully it's not backwards. That could sure get costly when I fire this puppy up. The pump is a standard Sauer Danfoss pump.
Here is the schema out of the manual that came with the Orbital Hand Pump
DRL said:Also are there more line that are not shown on the 3pt valve, I don't understand it.
I'm not sure what you mean? There aren't any more hydraulic lines on my 3pt valve.
DRL said:Thanks, keep up the good work
DRL
Thank you. Hopefully, we'll see how accurate I was soon
