Power Steering control unit -DK 35
   / Power Steering control unit -DK 35 #11
Just received an Email back from Eaton Japan and stated that they could not help me and i would have to work with the manufacture to solve any issues. So i am back to square one. $1600 for a power steering motor from Koiti. Not sure the tractors worth that.
Anyone have any recommendations on a reasonable and honest hydraulic shop. The reviews on the shops in my area are not good especially if you are not a normal customer.
Thank in advance.
I gave the EATON Japan email a try as well. I was told "Please contact to the machine manufacture's aftermarket support. Actually the steering valve is too old an already obsolete. We do not have any kind of rebuild kit."
Worth a try. At this point ptsg's recommendation, I think, is the best next route to go. Take the motor apart, measure up the seals and purchased them that way. If that doesn't work, a retrofit of a similar motor could also work out fine, seeing as how a motor like this would typically be about $200.
XCGREEN - i am open to a retrofit but can't find the technical specs of the current pump that i could match to a retro fit. Any idea of how to match.
PTSG, i have tried to source a good local hydraulic shop, most of the local shops get really poor ratings especially for a non-business customer. I am an engineer by training and am willing to pull the pump apart as it looks pretty straight forward from what i have seen on youtube. Any idea where i could source the seals. thanks
   / Power Steering control unit -DK 35 #14
Dadannyboy, I can offer up this page. This is the same system the newer dk35, 40, 45, 50se tractors use. I would imagine its very similar to what you have in the older dk tracor. This should definitely get you in the ballpark on flow rates and pressures.
   / Power Steering control unit -DK 35 #15
How did you go with this, I have a 2003 service manual/parts manual in pdf for it if you want it, I source seals from the internet, ebay etc, or online hydraulic shops
Unfortunately the parts list file doesn't go into a breakdown of the guts of the steering controller, so it appears Kioti don't sell the individual seals etc.
Steering flow is 4.7 gpm from the specs
Update. I ended up going to several hydraulic shops to try to obtain the parts to rebuild the unit with no luck. I finally found a local shop that had dealt foreign tractor parts. He ended up rebuilding it for $400 which included a year warranty. Works great so far.
   / Power Steering control unit -DK 35 #17
Not too bad at all considering. Good to know the parts are available somewhere. Any chance of getting the part numbers the shop used? Would be very useful.
   / Power Steering control unit -DK 35 #18
Hey Folks, I have a 2002 DK-35 and started experiencing hydraulic fluid leaking down the steering column. I pulled the column and it appears that the fluid is coming from around the gears of the steering control unit. I have been searching the forums for a rebuilt kit for the steering unit as I can't afford $1500 that a replacement would cost from a dealer. I have emailed several hydraulic shops and they are giving me estimates of $500 to rebuild and $750 plus to replace.
Has anybody rebuilt the power steering control unit and can provide the rebuild parts info or has anyone replaced the pump with something similar. I know enough about hydraulics to know that I can't throw any old pump on to replace.
The pump has a tag that states - Sumitomo, Eaton - Orbitrol power steering pump(model RW051B120R6A) off a 2002 Kioti DK 35.
Thanks Dan
I am having the exact same problem now were you able to solve the issue? My name is mark
   / Power Steering control unit -DK 35 #19
I am dealing with the same issue now in 2024. Can you help me as far as who you used to rebuild? Thank you very much. I have the same Tractor or Marklashway@gmail.com.
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
VENTRY FAN / BRUSH BURNING SKID (A55745)
VENTRY FAN / BRUSH...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2011 KENWORTH T800 (A55745)
2011 KENWORTH T800...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
