Power steering B8200
/ Power steering B8200 #2
I don't, but if you find a source for them let me know. I would love power steering on my B7100.
/ Power steering B8200 #3
Me two, with the fel loaded it can be quite difficult to turn my b7100, hence the evergrowing biceps /forums/images/graemlins/grin.gif
Mat
/ Power steering B8200 #4
I've looked.for my B8200. Would have to hit salvage yards.
It may be possible that the setup from a B20, B21, or B2150 might work. I have never had one side by side with mine to see.
/ Power steering B8200 #6
Guys: if you are lucky, you will find an old original Kubota add-on kit, like I did. It basically is a servo-valve (my term) and a double acting cylinder that fits where the original pitman arm is now. Works off the hydralic block via a pair of hoses and a check valve. It would have been a snap to install on my 8200 had there not already been a member supporting my FEL in the way. Anyway, I find it was worth the trouble, now that I have it. Works perfectly, like it should. The kit was put together by Kubota USA, partly OEM pieces and partly stock USA stuff. I had some images of it I could post, in case anyone is curious...
/ Power steering B8200 #8
Okay: here's a pic of the "servo" unit as I call it...
/ Power steering B8200 #9
and the rest of the steering kit...
/ Power steering B8200 #10
What problems did you have working around the loader supports?
I got my B8200 w/o loader. Two years later I added a Bushhog QT loader(looks like what you might have?).
/ Power steering B8200 #11
Sorry to take so long to respond- been busy. The left side loader bracket interferred with the ps cylinder and misc., and I had to remove a lot of metal. If you look at the photo again, you can see where it was cut out, front and back. I was concerned about weakening it, so it put a 3" x 3" heavy steel tube underneath, bolted to the bottom of each side. As we used to say in the midwest: it's hell for stout. I did have to notch the top of the tube so it would clear the drive shaft that goes to the front axle.
/ Power steering B8200 #12
Opps: I should have added that it is indeed a Bushhog QT loader. You're correct.
CASE CX60C EXCAVATOR (A65056)
CASE CX60C...
Unused Hydraulic EZ Remote Kit (A66734)
Unused Hydraulic...
2010 Dodge Charger Sedan (A66738)
2010 Dodge Charger...
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
HAMM 2210 SSD PADFOOT COMPACTOR (A67714)
HAMM 2210 SSD...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
