power steering b7100 kubota
   / power steering b7100 kubota #1
xr650lhonda
I have been thinking about using a torque generator to add power steering on my b7100 kubota will this work. I was going to cut the steering tube and put it in line with the shaft going to the gear box. will the tractor pump Handel this and what pluming will i need to to hook it up. here is the link to the one i was planning to use.
Surplus Center Item Detail
   / power steering b7100 kubota #2
The flow rate for the torque generator will almost be equal to the pump rate on the tractor.:D
Do a search for power steering and you will find a fellow here who has added one to his B7100.:D
   / power steering b7100 kubota #3
Here is a link to the thread Egon mentioned. I think it's a pretty slick mod.
Could I run it off the loader pump is there any way to install a bigger pump on the tractor looks like room is limited.
   / power steering b7100 kubota #5
You may be able to rig up a pump off the front engine splined??? It's not in a good location though.
A pump on the dynamo belt may be possible but it would probably require hood modifications.
The rear PTO is always possible but then it becomes dedicated.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
Toro Mower (A50324)
Toro Mower (A50324)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
