Power Shuttle problems
   / Power Shuttle problems #1
scanderson
Massey Ferguson 1643
I have a 2014 1643 Massey Ferguson Power Shuttle. It suddenly just started going forward only even in the neutral position. When I go to reverse the tractor will stop like it's in neutral. The micro switches at the shifter check good. If I unplug the connecter at the solenoids at the valve the tractor will not go in any direction do guys have any idea?
   / Power Shuttle problems #2
I don‘t know that transmission, but are you sure there is no mechanical linkage to the transmission?
   / Power Shuttle problems #3
If you disconnect all (both) of the solenoids you could verify if you are getting a voltage signal to them at the proper times.
Also both solenoids should ohm out the same often 5-8 ohms for the windings.
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
New Holland 155 Hay Elevator (A50774)
New Holland 155...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
