Power Shuttle operation and engine RPM?
   / Power Shuttle operation and engine RPM? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
My power shuttle works great. I have a NH TN70A. I bought the tractor used. I have read the owners manual which tells me how to use the PS.
The dealer service manager tells me I should not use the PS unless the engine RPM < 1500. The owners manual makes no mention of engine RPM.
Any PS owners willing to tell me how they use their PS? Any engine RPM limits?
Bob
   / Power Shuttle operation and engine RPM? #2
I use mine at what ever rpm I happen to be at. If I'm using the foot throttle I ususally back off. I've never attempted a 20+mph C range F-R shift and don't think I ever will, but I suspect the modulated Power Shuttle would handle it okay.
Andy
Andy
Nice to hear. I ask since I will soon be using a snow blower at 2200 engine RPM to get 540 PTO RPM. I would prefer to keep blower going at a steady 540 rpm while reversing directions. Dropping the RPM while running a snow blower to change directions would make for some hassles. I will avoid 20+ MPH F to R change as it would probably rip the heart out of my chest :D .
Bob
   / Power Shuttle operation and engine RPM? #4
I wouldn't use the power reverser in high range going fast, but blowing snow you would go slow anyway... engine rpms don't matter. I use switch mine back and forth at full tilt if I have to as long as im not into too high of gear going too fast.
Sounds like it makes sense. I would be in 1st gear, going at 2200 engine RPM, with PTO at 540, then I would need to be able to go F-R-F etc. when I get into a big pile of heavy wet snow that slows the blower so I can take smaller bites of snow.
Bob
   / Power Shuttle operation and engine RPM? #6
Bob
No problems here at any RPM with a 2120 like Andy's. The reverser is a treat, works easy under any conditions I've noticed. Mine has a switch to preset the quickness of the reversing, and the higher speed (rabbit) is my preference. Blowing snow, loading gravel, all easy for the PR. I think your TN won't have to take a second bite too often, though. You should have plenty of power for a blower.
Jim
Jim, you have a switch???? Wow, sounds very cool. Nothing like that on my TN.
So you can use your PS at 2200 rpm? Good to hear. If you can post a pic of your switch, that would be nice.
Bob
   / Power Shuttle operation and engine RPM? #8
Bob
Bob you have 70 HP so I don't expect wet snow to slow the blower down. Never had a problem with that blower on my 40D anyway. I think you'll do OK.
   / Power Shuttle operation and engine RPM? #9
Bob; I was playing errr test driving a TC55DA with HSS. I was informed it has a double wet clutch setup and when you move the lever from one direction to another it slowly clutches one motion and engages the next. Just like stopping with a clutch, shifting and releasing the clutch again with a manual reverser. It is so smooth at high or low rpm it makes the operator look like a pro. Can't wait to get my copy of this machine. I assume the TN has the same system a bit on the heavy duty side. I was really impressed with the ease of operation.
By the way... Keep the heavy snowfall on your side of the state. I just mounted a 5' western hydroturn plow on my 4110 John Deere. I don't believe it has the capacity for wet heavy drifts.
I assume the Power Shuttle = EHSS are they same, just different names for the same system.
You are sooooo right, it works so smooooooth. I spent today cutting up a fallen willow and moving a lot of tree. Then I went and scraped up some hore manure. The PS makes me look like I am driving a HST! Just that I do it at 1200 rpm and not 2400 rpm.
Bob
SNOW DOG SALT BOX TRUCK MOUNT SPREADER (A52577)
SNOW DOG SALT BOX...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
12ft Bushog Batwing Mower (A51573)
12ft Bushog...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
