Oil & Fuel Power Service fuel conditioner
   / Power Service fuel conditioner #1
L3130
NH
Kubota L3130
I put 16oz fuel conditioner in my fuel tank of my L3130 which only holds 10 Gals of fuel is that enough? I did mathmatics and it came out to be approx 3 oz to 1 gal of gas. I know it should be 30oz, But that seems way to much. Weid becuase on the bottle it states it treat 100 gals of fuel. Is there any harm by adding to much? Please help a newbie.
   / Power Service fuel conditioner #2
From Power Service > Part No. 1016
Add 16 ounces to each 35 gallons of diesel fuel. For faster injector clean-up and maximum cetane boost, add 16 ounces to each 18 gallons of diesel fuel.
So I put to much, I just wasted it all huh? Think it will it be ok though?
   / Power Service fuel conditioner #4
I don't think that it will hurt anything, but you did put quite a bit.
   / Power Service fuel conditioner #5
I use 3 oz per 5 gallons in both my Kubota tractor and IH dozer. I use off-road fuel exclusively and this mixture with both winter blend and summer blend fuel.
   / Power Service fuel conditioner #6
</font><font color="blue" class="small">( wasted it all huh? Think it will it be ok though? )</font>
Nope, didn't waste it all; just part of it. /forums/images/graemlins/wink.gif But, yes, it's OK; no problem.
   / Power Service fuel conditioner #7
I use Power Service Diesel Fuel Supplement part # 1025 It's the 32 oz. size that treats 100 gal. For 10 gal. divide by ten or 3.2oz per 10 gal. For faster injector cleaning the instructions say you can double the amount or 32 oz. per 50 gal. In your case that would be 6.4 oz. per 10 gal. I don't know whether the fuel conditioner is different from the fuel supplement but the usage is still the same. 16 oz per 10 gal. is a bit much but probably won't hurt anything.
   / Power Service fuel conditioner #8
Right after I got my new JD4110 tractor; I somehow put
32oz of Power Service Diesel treatment in my 5 gallon tank.
Thought for sure I was in trouble. Ask people on this forum;
What now? General opnion was that it wouldn't hurt it. I run
it part way down and added fuel. They were right. It didn't
hurt a thing. Don't ask how I could make such a dumb
mistake. It was easier than you'd think.
   / Power Service fuel conditioner #9
I use 2 ounces per 5 gallons in my L3130 and ZD21. You can use 3 ounces per 5 gallons. It shouldn't hurt anything to add a little extra one time. When your tank is about half empty fill it back up with straight diesel. Should be good to go.
Curt
Great to know. I won't add any more till I need to refuel. Thanks for the help. /forums/images/graemlins/grin.gif
Kivel 3500 Lb Pallet Forks (A50121)
Kivel 3500 Lb...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
Wolverine Quick Attach Manure Grapple (A50515)
Wolverine Quick...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
