Power Service and Fleet Charge
Status
Not open for further replies.
   / Power Service and Fleet Charge #1
fivestring
South Central NC, USofA
Iseki TU1700f
I was at TSC this past weekend to pick up some Power Service. Well, they had white and silver containers, and not knowing which to use, I bought one of each. Which is better for my mid to late eighties Iseki TU1700f with a 3 cylinder Iseki diesel?
TSC did not have have Fleet Guard antifreeze; they had Fleet Charge. What is the difference? I only bought one a gallon of the Fleet Charge.
   / Power Service and Fleet Charge #2
white has the anti-gel in it and silver has just the clean stuff in it.
   / Power Service and Fleet Charge #3
The silver bottle is suppose to be a concentrated formula, but as Mike said, no anti-gel additives.
   / Power Service and Fleet Charge #4
Use the silver in the summer and the white in the winter.
   / Power Service and Fleet Charge #5
Basicaly the Difference is
white 3 cetane
Anti-gel + pour point increasers
Silver has no anti-gel + pourpoint
has 3-6 cetane
   / Power Service and Fleet Charge #6
If you use the white stuff can you use straight #2 year round? Or would you still get the winter diesel?
   / Power Service and Fleet Charge #7
Where you live, you shouldn't need the antigel, so you can use the one without it. The only time you need the antigel is if it gets real cold there, and I don't think it does where you live. You may feel cold, but not cold enough to bother the diesel. /forums/images/graemlins/smile.gif
   / Power Service and Fleet Charge #8
they told me when i emailed them that you can only use #2 diesel with there product no #1 they said it wouldn't blend /forums/images/graemlins/confused.gif don't ask me why or how.
I had a friend who collects the old time gasoline pumps that are clear he put some in it as he stores diesel in it. To his suprize it didn't blend it sunk to the bottom so after him telling me that i emailed one of the tech people. Never been able to figure out why it didn't blend in his #2 or why they say not to use with #1?
   / Power Service and Fleet Charge #9
I would make sure you add whichever one correctly. If you add too much you could burn out injector(s). It is not that common but if you added like 1/2 gallon in a BX22 watch out!
Really you should not need to add anything to fuel if you have good clean fuel .Jsut buy it with the big rigs! /forums/images/graemlins/cool.gif
I know when I had my F350 POwerstroke the Power Service was a no no in the fuel.
   / Power Service and Fleet Charge #10
I hate to ask as i'm hoping not to start another WW3
but you noted that powerservice was a no-no in a powerstroke? The same products used in PS is used in rotella Dfa and most popular fuel additives. I asked a simualr question to powerservice and they said a increased dose wouldn't hurt they indicated it was ok and that it was tested to clean depoists on pistons that was approx. 3-5x the recommended dose granted if you run the product almost straight it would probaly gall the pump or injectors /forums/images/graemlins/confused.gif
The only no-no i know of is FMC's no cetane booster. Just wondering what chemical or basis on finding that conclusion or was you talking about running about straight product?
thanks
Status
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
2010 International Prostar (A47477)
2010 International...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
