Power Reverser Plus 24/24 / 32/16
   / Power Reverser Plus 24/24 / 32/16 #1
Edward. S
Platinum Member
Somewhere
John Deere
How do you use this transmission? Please post details below, if you have pictures that's great thanks.
BUMP!
   / Power Reverser Plus 24/24 / 32/16 #3
What model tractor is it?
   / Power Reverser Plus 24/24 / 32/16 #5
ON the 5425, there is a Range lever with three ranges, A, B, & C. You must stop and use the clutch to change ranges.
There is a Gear lever with four gears, 1-4. You must clutch when shifting gears, but this can be done ''on the go', NO need to STOP as with the Range shifting.
The PLUS is a HI-LO feature. On the side of the gear shift knob are two buttons, top one has a Rabbit, bottom one a Turtle. While in any Range or Gear, you can push the Turtle button (without clutching) and drop down about 1/2 as much as compared to shifting the Gear shift lever to the next lower gear. Push the Rabbit button (without clutching) and you up shift back to the gear you are currently in. So the 12 speeds of a 5425 become 24 and since you have a Reverser, 24/24. The 5M series you can get four Ranges x four Gears = 16 speeds and with HI-LO, Reverser = 32/32
Reverser is a lever that allows changes from forward to reverse and reverse to forward in any range/gear without clutching. It can make for some very FAST backing, be careful!
Wow, thanks it was exact awnser I was looking for! Must be a handy tranny when loading or baling. Why do they call it a 32/16 and not 32/32 then
   / Power Reverser Plus 24/24 / 32/16 #7
Maybe HI-LO is deactivated when reverse is selected? Only a guess.
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2014 Ford Escape (A50323)
2014 Ford Escape...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
