Power Rake ??
/ Power Rake ?? #1
AltavistaLawn
Has anyone here used the power rake attachment on a PT?
Just wondering how it performs?
/ Power Rake ?? #2
We use a power rake on our 1460 with a laser reciever to cut beds for driveways and sidewalks on grade. Also leveled a 40000 sq ft building pad in about 4 hours, within 1 inch. We have the laser reciever feed a proportional valve to automatically adjust the height of the power rake, thus all the operator has to do is drive. We paid for this tool in one job.
EB
/ Power Rake ?? #3
That's pretty cool! I'd like to see that in action!
/ Power Rake ??
</font><font color="blue" class="small">( That's pretty cool! I'd like to see that in action! )</font>
Me 2 !!
Sounds over my head though. /forums/images/graemlins/smirk.gif
/ Power Rake ?? #5
I'm intrigued how does that work? I don't understand what the laser receiver does. I'm guessing it adjusts the height relative to some setting but I need more details if you don't mind helping the ignorant.
/ Power Rake ?? #6
I've personally used my powerrake and did have it for sale and decided to keep it. I'm a landscape designer and live on 6 acres and use it weekly renovating different parts of my yard as well as renting it out to both by company for grading and some of my buddies who are in the business. It's awesome once you get the hang of it. I highly recommend it. It too acts as a tiller with the depth adjustment screw if need be. Up to 12" . If you need more, scoop out and continue tilling. Stips sod and grades in two passes.
/ Power Rake ?? #7
Scotchers,
What size PT are you using?
Before I bought my 425 I asked about using the power rake as a dual purpose tiller and was advised against it.
Perhaps it depends on size of tractor or type of soil: loose; sticky clay; rocky, etc.
/ Power Rake ?? #8
I have a PT 425 and it's does a great job. The only thing I've found is due to it's size, when your using it as a tiller, you have to be more patient and not AS aggressive. But all in all, I've had NO problems, Doesn't jam like the tiller
/ Power Rake ?? #9
Which way are you running the rake for leveling?
Mine is set with the top running toward the tractor and the bottom running away from it (i.e. it would be pushing the tractor backward).
Seems like this is right for agressive soil breaking, but don't know why PT has the rubber flap like it should be the other way. It seems to take some serious power when I put some pressure on it; not saying good or bad about that, just pointing it out.
Thanks!
Blackwell's laser sounds way to sweet, but I'm sure the price is way too forbidding for anything I'd have.
/ Power Rake ?? #10
Well, the power rake seems to work pretty slick for loosening surface soil & knocking off the high spots, but more questions (and I'm still trying to figure out why the rubber guard looks like it should turn the other way):
Barring the integrated laser level. How do you control the depth to create a level surface? I'm pretty quick with the joystick, but always seem to recognize the need for adjustment after it's too late.
Also (and here barring the tilt proposed in another thread), how do you control the tilt for a level surface?
I'll be happy to feel like an idiot if I'm overlooking something really simple! /forums/images/graemlins/grin.gif
Oh, I'll have to add this to another thread too, but based on a really quick trial, it's not bad as a "mini-sheep's-foot" when the hydraulics are turned off.
/ Power Rake ?? #11
Use the front caster wheel kit, set the desired height with spacers on the front and sliding the rear wheels up or down. Set the power rake on the surface on all four wheels, put the arms in float and drive forward with the drum rotating in reverse. The rubber flap prevents the dirt from flipping over the top and back on the tractor. This is one of the best attachments we ever purchased. We tried the Harley Rake but the drum is too small, the PT rake will do three times the work.
The laser control is great for cutting surfaces level or on a controlled slope, but most our work is done without it, to contour surfaces prior to seeding.
/ Power Rake ?? #12
Well, you could use the poor man's laser level.... a string line. /forums/images/graemlins/grin.gif
/ Power Rake ?? #13
You got it MR, I'm planning to go poor man with a ball of string for level and 50ft of hose & a tape measure (aka water level) to set the pitch.....irronically she now can't decide if she wants 0 pitch or something like 1" in 10' (is switching building contractors - and hearing different options), so I have a little time to ponder further.
I was hoping for a better way, but I guess it gets the points marked all the same! /forums/images/graemlins/tongue.gif
/ Power Rake ?? #14
Blackwell,
Thanks so much for the great instructions! /forums/images/graemlins/cool.gif The previous owner said I'd want to add the front wheels if I used the rake much, guess he was exactly right.
Still envy your laser, but think some getting used to it and I can get great results even with "old-school" level marking.
I think I understand the flap now too. Perhaps, being strapped to the trailer it developed a curvature toward the wheel and just got sucked in [I noticed that before I bought it too]. Bet if I turn it [upside-down] or make a new straight piece it will be perfect for it's intended purpose. /forums/images/graemlins/smile.gif
Thanks again, Blackwell!
/ Power Rake ?? #15
This maybe should go in safety or where ever "stupid operator tricks [errors]" go these days so everyone can get a chuckle at my expense, but it's kind of PT specific.
I have the tiller and rake, so my trailer has a rack above the tiller for the rake. I was testing the rake (prior to doing the job I mentioned before) and putting it back on the trailer right before leaving for the job. Put it on the rack started backing away, not even 10 seconds latter THUNK!!!! I hadn't set it perfect, the wind caught it just right vibrating the rack, and of course it wasn't strapped yet.
Nasty dent in trailer: /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
Asked wife to back onto trailer while I showed her were to stop (she only ran for 2 minutes previously - big mistake): wife backs into rake: /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/frown.gif
Well, finally got it off, BTW I think it weighs 500lb or more; when I chained it to the hoe [granted mostly extended], it lifed the front end off the ground!
Nobody hurt! /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif Rake barely even traded paint. /forums/images/graemlins/cool.gif Trailer still has dent /forums/images/graemlins/frown.gif But think I can fix. /forums/images/graemlins/tongue.gif Nobody hurt! /forums/images/graemlins/smile.gif [had to end on happy note]
/ Power Rake ?? #16
Chad,
Sounds to me not so much like "stupid operator tricks," but more like a report on the learning curve that we call life. Me thinks that we have all been your boat, or one very similar. I've heard that it only becomes 'stupidity' when one does it repeatedly. How many times qualifies as 'repeatedly'?? Hmmm.....I don't know the answer, but let's not be too harsh on ourselves.
/ Power Rake ??
I used a Bobcat brand, after we made the adaptors. Worked great..but had to stay on the hydraulics to control it.
/ Power Rake ?? #18
Great Picture AltavistaLawn! /forums/images/graemlins/cool.gif Thanks. /forums/images/graemlins/smile.gif
Just further confirms my need for front wheels though. /forums/images/graemlins/frown.gif
And the list of projects to properly configure the machine to tackle the list of projects grows! /forums/images/graemlins/grin.gif
/ Power Rake ?? #19
<font color="blue"> I've heard that it only becomes 'stupidity' when one does it repeatedly. How many times qualifies as 'repeatedly'?? Hmmm.....I don't know the answer, but let's not be too harsh on ourselves. </font>
Pretty good advice Tracdoc!
Actually, I didn't post it to be hard on myself (though I was for a few minutes after it happend). Just hoped others could chuckle at it, that way some good could come of the bad! /forums/images/graemlins/grin.gif Somebody might learn from my mistake. /forums/images/graemlins/cool.gif Or, it might make their mistakes seems smaller. /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
