Power rake?
/ Power rake? #1
Tchamp
Baldwin Georgia
Power trac PT-2422
I have a power rake attachment and not sure how to use it or what it’s purpose is for the power trac configuration, it looks as if it could be used for removing roots, small trees and leveling ground.
/ Power rake? #2
That looks mor like a sheeps foot compactor. But looking on-line I see it's a rake. Does it not angle for windrowing material? I have an 8 foot Harley rake and the angling is kind of key for most work.
Just think of it as a planer of sorts. Not really for removing trees. Mostly for breaking up and levelling ground.
/ Power rake? #4
:laughing: What exactly is he trying to accomplish?
/ Power rake? #7
It may look like a compaction tool, but that isn't what it does. It grinds to a set depth.
It's used to level soils prior to seeding or for sod, although I guess you could use it as an intermediate step in foundations between compaction rounds. The four wheels set a level plane that in successive passes tend toward level. It is quite fast compared to the alternatives, until you step up to GPS control.
All the best,
Peter
/ Power rake?
All the best,
Peter
Thank you for the info. Much appreciated
/ Power rake? #9
It windrows fine. The tool doesn't need to angle. The machine articulates.
/ Power rake? #10
Does anyone have experience with this attachment?View attachment 678386
If you ever decide to sell it, I would be interested in buying it
/ Power rake? #11
Used for grading. It pulverizes and levels soil while removing debris to create a great seedbed. I also use it to smooth out existing lawns without removing all the existing grass. It also works very well grading gravel driveways.
To use it, adjust both front and back caster wheels to control your depth. Don't try to cut too deep.
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2019 FORD F-350 SUPER DUTY (A65643)
2019 FORD F-350...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
White Metal Roof Vents (A64194)
White Metal Roof...
AMADAS SPC4 - 4R COTTON STALK PULLER / CHOPPER (A64276)
AMADAS SPC4 - 4R...
