Power rake project
/ Power rake project
Zick
Formula I have for figuring torque is torque (in lbs) = HP x 63025
RPM
17 x 63025 = 1071425 / 540 =1984 in lbs torque
the reason I questioned this in the first place is I figured pump HP by taking 3.7 GPM x 2500 PSI = 9250 / 1714 = 5.4 HP to drive the hydraulic pump.
Well it looks like you might be correct. Glad I asked. I did rerun some numbers w/ bigger pumps to get closer to the same torque rating but the speed would have dropped down to around 120 rpms which is probably too slow.
/ Power rake project #12
I should ask, is the power rake for the front or back?
If you had 10 GPM for a 10 cu in hyd motor, it would run at 231 rpm. Torque 4,777 or 398 ft lbs
The hyd pump takes about 21 HP to pump 10 GPM and a pressure of 3000 psi.
With an 85 % efficiency, the 21 HP from the pump would give the hyd motor about 17.85 HP.
If you have more GPMs, you will have more rpms.
I just noticed the flow on your tractor.
Hydraulics:
Type: open center
Capacity: 3.1 gal [11.7 L]
Total flow: 6.3 gpm [23.8 lpm]
It's for the rear.
The total flow isn't what's available at the FEL ports from what I've read, only about 3.7gpm and it looks like the factor BX7326 rear remotes only provide the same 3.7gpm.
I've thought about getting a PTO pump but then I would have to have some kind of oil tank, filter, etc as well and then it get more complicated and cost prohibited.
So at this point, it looks like I'm going to have to go back to the PTO gearbox setup, too bad. :(
/ Power rake project #14
I wanted one on the fel of my 1026r but came to the same conclusion that it wouldn't have enough power to do any real work. I am going to build a pto unit too.
Even thought I ended up going with a mechanical PTO driven rake, I just found this video of a guy who build one using a rear PTO pump. It's pretty large but seems to work well.
https://www.youtube.com/watch?v=bkt7qMbsiwk
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
GMC 2500HD 4wd Service Truck (A61307)
GMC 2500HD 4wd...
2014 Scag STT61V 61in Zero Turn Commercial Mower (A59228)
2014 Scag STT61V...
159119 (A60430)
159119 (A60430)
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
