power port wiring
   / power port wiring #1
mitch G
John Deere L120
A rodent ate through the white and black wireds running into the Power Port of the L120. I discovered this after I had a problem starting. I have capped them off. still can not start. I wonder is the power port connection back wired through something that would ground the tractor or otherwise prohibit starting? Be warned I am not very mechanical.
   / power port wiring #2
not sure about that, but cant you just wire nut the cut wires back to where they should have been before mouse chewed thru it?, instead of just capping them off?
   / power port wiring
yeah that;s tomorrow's plan
   / power port wiring #4
The power port might be on the same fuse as something need to start the machine. Leave the wires capped and then check your fuses.
   / power port wiring #5
Have you looked for other chewed wires?
   / power port wiring #6
that my thought........ more chewed wires......
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
