Power Pole part II
   / Power Pole part II #11
Bird said:
That sure sounds unusual to me because all my experience has been that the power company will not set a pole on private property without an easement from the property owner, so you would be wasting your breath telling them to move it.
Bird,you are 100% correct on the easment comment.coobie
   / Power Pole part II #12
They may do things different in Texas but these poles are over 70 years old and they were placed on private property WITHOUT an easement.
   / Power Pole part II #13
coobie said:
I would have told your neighbor I will remove your electric pole and your power to.The reason power companys dont want signs with nails and garbage on there poles is that if the pole has to be climbed it can injure a lineman if he cuts out and falls into old nails,bolts,yard lights and so forth.I have been a electric lineman for many years so I can vouch for this.coobie
They stopped climbing poles here 20 years ago. They won't do any work at all without a bucket truck now.
   / Power Pole part II #14
Boy I need a job down there is guess.We still climb poles here on a weekly basis.coobie
   / Power Pole part II #15
Another pole and line was set in my backyard without my permission or an easement after Katrina when a neighbor got a FEMA trailer put in his backyard and needed electric and didn't want the wires running through his yard. Being a good neighbor, I did not protest this thinking it would be temporary. Two and a half years later it is still there and the neighbor has put a shed in his backyard and wired it up so it seems that they believe this is a permanent situation.
   / Power Pole part II #16
I guess they do things different down in your neck of the woods.Since the late 1930,s-1940,s up here our power company needs easements for every pole we set,in fact we can,t even break air space going over a neighbors property to get power without both partys sighned consent.coobie
Thanks for the info everybody, I don't think they climb poles here anymore either.
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
1990 KENWORTH T800 FUEL AND LUBE TRUCK(INOPERABLE) (A50854)
1990 KENWORTH T800...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
