Power Pole part II
   / Power Pole part II #1
RedRocker
Bowie TX
Kioti CK30 HST, dual remotes, FEL.
Has anybody ever mounted anything on their power pole, or is that a no no?
I was thinking about sticking a wifi antenna up there to try and snag some of Jinman's internet. Of course then there's the problem of killing myself getting it up there, but that's another problem.
   / Power Pole part II #2
Around here almost all power poles are on the highway right-of-way and it is illegal to post anything on them. However, I have one in my backyard that I run my surveillance camera lines on and if they tell me to move my wires, I'm going to tell them that it's on my property and they have no right to have their pole there and if they don't like it they can move their pole.
One of my neighbors had a sign on a utility pole and it was in his front yard. They told him to remove the sign and he told them to remove the pole. He never heard from them again. :)
   / Power Pole part II #3
ive got 3 polls in my front yard carying my service. The last one put up by me.
Ive mounted stuff on them. I plan on putting up a 2x4 holding about 6 bidhouse gourds.
   / Power Pole part II #4
I have a birdhouse on the one in front of my house. I would be scared to put an antenna on it though. JC
This is the pole my power box is on, it has one of those dusk to dawn lights on it without a bulb in it. It's well within the confines of my property, so that's not an issue.
   / Power Pole part II #6
I'd go for it, if I could do it without getting electrocuted.
   / Power Pole part II #7
If you own the pole you can hang a light or dish on it. I had to buy a pole to set in between my house and the pole on the street. Power comes from street to my pole then underground to house. I added a 110V outlet on my pole and will add a light later.
   / Power Pole part II #8
That sure sounds unusual to me because all my experience has been that the power company will not set a pole on private property without an easement from the property owner, so you would be wasting your breath telling them to move it.
   / Power Pole part II #9
Being a electric lineman I say NO !! If someone has to climb that pole in a pair of hooks and belt and cuts out and falls into the antenna he could get hurt.In my neck of the woods our power company wants folks to keep stuff off our poles.coobie
   / Power Pole part II #10
I would have told your neighbor I will remove your electric pole and your power to.The reason power companys dont want signs with nails and garbage on there poles is that if the pole has to be climbed it can injure a lineman if he cuts out and falls into old nails,bolts,yard lights and so forth.I have been a electric lineman for many years so I can vouch for this.coobie
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
1269 (A50490)
1269 (A50490)
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2003 PETERBILT 330 CARGO TRUCK (A50854)
2003 PETERBILT 330...
