Power Point
/ Power Point #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Why don't they put power points (cig lighters) on tractors? They would be great for portable compressors, work lamps and spot lights for jack lighting. I'd put one on mine but there is no place to pick up 12vs all the wiring is sealed.
/ Power Point #3
Go to a marine dealer and pick up one with a water proof outlet cover. I have one on my boat that has been there for over 5 years and still perfect. It is not a dash mount but flat surface mount and when not in use the cap makes it watertight. I have used it in salt water fishing and no corrosion. I ran direct from battery with inline fuse so it is hot all the time but you should be able to come off the ignition wires to jump one if you only wanted it powered when the ignition is on.
I used mine for GPS so I wanted it on all the time.
/ Power Point #4
i can confirm, the marine ones, i have one at the rear for the beacon rotating light, i also have a car one in under the dash for incase i need it, you could run some wires back to the battery and use a water proof fuse holder
cheers stuart
/ Power Point #6
I mounted a regular cigar lighter up under the roof beside the Pioneer radio. Radio lasted about 8 years, lighter quit shortly after...
/ Power Point #7
/ Power Point #8
Hiya
My Kioti RX6010 comes with a cig lighter socket in the cabin.
It will get used to power a drink cooler :)
Mike
/ Power Point #9
easy to add with those adapters that have a cig socket and gator clips.
/ Power Point #10
Because if they added one you wouldn't need to buy the custom accessories your dealer would love to sell you.
/ Power Point #11
I have a 71 model 4020 john deere that came with a cig. lighter.
Maybe it is the brand you have that is the problem.:laughing:
2000 International 4900 Tandem Truck (A66285)
2000 International...
UNUSED SDLANCH 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
2016 Freightliner 114SD T/A Lely 3,300 Gallon Septic Wet Vacuum Truck (A61573)
2016 Freightliner...
ASV Engine & Parts (A66285)
ASV Engine & Parts...
Kubota M4700 (A60462)
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
