rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,983
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
The following quote on was posted today - I don't know if the numbers are right or not...they seem sort of large. But true or not, it certainly leaves the wrong impression. Let me explain why....
"ALTIITUDE - Tractors lose 3% of engine power output for every 1,000' altitude increase, over 1,500' Sometimes twenty posts will be made advising on tractor horsepower, then we find OP is a 6,500 feet altitude and is considering a low power, naturally aspirated tractor."
I live at 7000 feet altitude & have quite a bit of experience with engines here. The numbers in the quote above give the wrong impression about the real effects of power loss. In most cases an operator will simply open the throttle a little farther and run at a slightly higher RPM. He won't even notice a slight loss in efficiency. So although the loss of theoretical maximum power may be real, it isn't something that is normally a factor
Of course an operator who likes to run with the throttle wide open against the stops at all times might feel shorted, but that's not normally how one operates a tractor.
rScotty
rScotty
