Power-loss 48 BH
   / Power-loss 48 BH
Yes running at the same RPM.
   / Power-loss 48 BH #12
The gurgle sound may be air in the system. To remove the air you need to cycle all the cylinders from stop to stop. Your hydraulic fluid level could also be low but I believe you said it wasn't. I think air in the system would just make the operation jerky though. The sound you hear may also just be the hydraulic fluid rushing through a stuck relief valve. Since the unit is pretty new it is quite possible that a piece of trash got lodged in a relief valve causing it to leak. If you still have the problem after you cycle the cylinders to remove any trapped air, I would just let have the dealer check it out.
The BH should easily lift the rear of the tractor. You could pick it up and move it side to side but the JD says not to do it (might bend a cylinder rod). About the only reason it would not lift the rear of the tractor is low hydraulic pressure and that is likely due to a bad or stuck open relief valve.
You can check all the obvious things that are less likely to cause your problem like making sure both hose connections are secure, that all the grease points are greased (there are a lot of them on the 48BH), the tractor is fully warmed up, and the engine speed is adequate. The linkages to the control valve could be loose so you could check them also. The BH is made in the US or Canada so the quality is not comparable to the tractor which is made in Japan. On mine the reason it bent a cylinder shaft was that the factory installed a relief valve backwards so it did not work and that was a fairly common problem along with installing the wrong valves.
   / Power-loss 48 BH
/forums/images/graemlins/confused.gif JD Dealer picked the tractor up Monday - Called today and was told the pressure checked within spec. Pushed the fact that it would not pick the back of the tractor off the ground and he told me they compared it to one on the yard with no appreciable difference. Not looking good for the home team!
Will yours pick the rear tires off the ground?
2008 UTILITY DRY VAN TRAILER 53X102 (A57880)
2008 UTILITY DRY...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
2006 Grove TMX25 (A55973)
2006 Grove TMX25...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
