Power lift for cargo box problems
   / Power lift for cargo box problems #1
SamIamfromNC
John Deere Gator utility Vehicle HPX 4x4 & Trail HS 4x4
We have a Gtor UV HPX 4 x 4 Trail HPX 4 x 4. It has a power lift to raise the cargo box to dump things and it will not raise. Any thoughts on problems that might cause this. Could this be a fuse or lack of hydraulic fluid? Also, since it won't raise, how can we manually raise it to check the oil and hydraulics until we figure out the problem. It does not have the lever between the seats that unlocks it to manually raise one that doesn't have the power lift.
Samiam
   / Power lift for cargo box problems #2
Will need to go under the box and pull the pin(s) holding the power lift actuator to manually lift the box. Will need to track down the problem. Look for missing 12v.
Hydraulic fluid not a likely problem, as the lift mechanism is a linear actuator (12v), possibly part # AM145903
   / Power lift for cargo box problems #3
It could definitely be a fuse or low hydraulic fluid causing the issue. I’d check the fuse first to rule that out, and if that’s not it, then it’s probably low fluid or a hydraulic issue. Since you don’t have the manual lever, you might need to disconnect the hydraulic cylinder to lift it manually, but be cautious as the bed could be heavy. A jack or some kind of support might be helpful to lift it safely while you check the hydraulics.
   / Power lift for cargo box problems #4
Welcome to TBN I hope you realize that this thread is about 3 years old and we hope that the OP has figured this out by now.
Richard
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
1269 (A50490)
1269 (A50490)
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2008 Ford F-250 Service Truck (A50323)
2008 Ford F-250...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
