Power King hydraulic pump
   / Power King hydraulic pump #1
JAMES NICHOLSON
lisbon.ohio
cub super lt1550,ford lgt 100,simplicity,wheel horse, murry
I was given the complete hydraulic system off of a Power King that I want to install on a Sears ST16 tractor just for a snow blade angle and lift. The problem is I can't find any specs on the pump concerning the GPM. I called Webster and they had no specs on this pump. I will include some pics of the pump and everything.Any help greatly appreciated. IMG_0758.jpgIMG_0668 (1).jpgIMG_0759.jpgunnamed (1).jpg
   / Power King hydraulic pump #2
Is there a manufacturer name marked on the pump somewhere?
Anyway, looking at the size of the pump, I think it'll be just fine for you application. If anything, you can always set the relief valve a bit lower, if you find the engine is working hard.
What I cant find is the GPM at....say 1000RPMs. The pressure will be fine.
   / Power King hydraulic pump #4
You can always open the pump and measure the gears to figure out the displacement. I've done this in the past with unknown pumps using the Surplus center guide.
Here is the link: Surplus Center
By the way, Lisbon is the capital of my country.
Thank you for the link. I will try that or "CC' it. Turn the pump at a slow RPM for a minute and measure the output. Then do the math.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A56438)
2011 Ford F-550...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56438)
Gleaner N630 Corn...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
17101 (A55851)
17101 (A55851)
