power drain on dodge.. got a fuse / circuit question
   / power drain on dodge.. got a fuse / circuit question
I wonder if they have the trailer power, charging the breakaway switch battery..?? They had our dumptrucks wired that way. Removing the b-away battery + terminal wire should tell you pretty quick.
Just a thought...
i know some of our trailers are wired like that. however in this case it was not hooked to a trailer when it died.
however as others said. I will be checking the 7 pin and the jumpe rharness for any corrosion that might be letting power find ground thru that nasty green stuff.
thanks for the ideas guys.
lookign at everything.. not ignoring even the smallest comments.
will let you know what monday shows. :)
and the weekend report.
no dead battery.
it's whatever is on that 40a fuse. and brake circuit that is doing it.
pulling that and the bat don't go low.
can only assume the brake controller is just getting a lil power hungry in it's old age.
   / power drain on dodge.. got a fuse / circuit question #13
Did you ever try it with the 40a fuse in BUT with the glovebox light fixed? Otherwise, how do you know it wasn't the glovebox issue that fixed the problem??
Also, when checking amps inline, did you wait a few minutes after hooking up to let the ecm/pcm power up and then go idle. Any reading within the first minute or so is a false reading.
One more thing, did you unhook the hood light? The power draw should be closer to 50mA, 100 is pushing the upper limits.
yes, unhooked hood lamp.. and did wait for the timer on the ecm / pcm
no, i don't think he tried it with the fuse in.. .. as we removed the fuse and pulled the glove switch at the same time.
good idea.
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
New/Unused Electric Golf Cart (A57453)
New/Unused...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2022 Behnke Trailer (A55973)
2022 Behnke...
Pallet of Miscellaneous Electronics (A56860)
Pallet of...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
