POWER BROOM
/ POWER BROOM #1
TRUKFXR
Bronze Member
Illinois
Gehl AL20DX
Living here in Illinois, I have been doing a lot of snow plowing lately. I use my pickup truck to do my gravel driveway and now I have a yard full of stones that have been thrown by the plow. It is worse this year because of the number of times I have had to plow. In the past I have used a power rake (looks like a weed whip with a rubber drum)
and it works ok, but because my drive is over 1500 feet long, it takes quite a bit of time to do both sides.
I keep thinking about a power broom, like the 48'' one that Power Trac has and mount it to my Gehl Al20dx, but its a lot of money and if it doesn't work well, I will own a piece of equipment that has no other use. No matter how well it works, it is still a lot of money to rake the yard once a year. Finding anything used that isn't a piece of junk or needs too much work to adapt seems impossible.
Not sure what my question is. I guess, does anybody have any experience with a broom for this purpose? Any inexpensive units out there that I can adapt?? Anyone own the 48'' Power Trac unit?
/ POWER BROOM #2
I have no first hand experience with them, but you may keep an eye out for a used Sweepster brand of broom. Or, they're available, hydraulically-driven new but I have no idea of the price.
Paladin Light Construction Group
They're also made with a variety of front-drive systems, either belt or PTO shaft, in a wide range of sizes. The actual broom itself is chain-driven from the side, similar to a tiller.
Here's a pic of a used one on a big Simp garden tractor:
/ POWER BROOM #4
I don't have the PT sweeper but I converted a sweeper to work with my PT. I use it after I roto-till the garden to sweep the dirt along the edges. I also use it to sweep small rocks from the side of my driveway. Mine is suspended by a heavy spring and when I use it on my lawn the brush easily pulls into the grass and stops spinning. It requires constant leveling making it hard to do large areas.
http://www.tractorbynet.com/forums/power-trac/81678-red-green-sweeper-project.html
In the future, I intend to attach wheels that will allow height adjustment and hopefully prevent the brush from being pulled into the turf. I assume adjustable wheels would allow turf work such as dethatching and sweeping gravel from grass.
Dale
/ POWER BROOM #5
It's fun to have your own equipment but for one job per year, I would recommend renting a sweeper. I think they go for about $100 per day for a walk behind. And you must be one tough guy. I have one of those hand held power brooms and I can't imagine cleaning up a 1500ft driveway with it.
/ POWER BROOM #6
Dale, I probably missed it, but what kind of driveway do you have (material)
In this pic:
http://www.tractorbynet.com/forums/...red-green-sweeper-project-907489-img_0050.jpg
It almost looks like asphalt. If it is not, what materials did you use to make such an impressive and neat looking drive?
I too have a long gravel drive, it looks no where near what yours looks like.
Thanks for the pics, they look great.
/ POWER BROOM #7
My driveway is recycled asphalt. I live on a township road. About five years ago we convinced the township that considering the amout of property tax we paid in relation to farm land tax we deserved a paved road. The county paved it with recycled asphalt and the company doing the work offered to do mine for about $2,000. My drive is 300 feet long.
Within six months, I needed to replace my septic tank. The large backhoe was not kind to my driveway. In the near future I intend to have a 3 inch asphalt mat laid on top.
Dale
/ POWER BROOM #8
Having grown up with a gravel driveway, I don't know know of anything that can plow it without moving the stones.
You can get leaf vacuums; you do one pass at low speed to get leaves, and then a second pass at high power to suck up the loose gravel.
Off topic a little: Dale-
When you put the new asphalt down, try to specify that they use a heavy duty geotextile between the two layers. This will prevent cracks from directly through your new asphalt. It works wonders.
Asphalt takes some time to cure, so if you can stay off it for awhile after it is laid, especially with anything heavy, you will get a longer life out of it. (As you have learned the hard way...)
All the best,
Peter
Dale
/ POWER BROOM #9
Peter,
Thanks for the advice. I will investigate heavy duty geotextile.
Dale
/ POWER BROOM
RegL,
Since you have used one of those brooms (mine is a Stihl with a 22'' rubber drum)
then you can understand why I am trying to find another method to clean up the mess.
I am actually doing about 1600 ft. and as you know, when you use the broom you have to overlap some and really don't clean all the stones with just one pass. One thing I did do was make a set of wheels to help support the unit and that makes it a little easier. I am not sure you have to be tough to do it but being "dull'' helps.
/ POWER BROOM
Dale
Dale,
Where did you get the motor for your sweeper? I am thinking about making my own sweeper and that would be something I will need. I will need wheels too, but haven't begun to look for them yet. Any suggestions where to find Wheels & yokes etc?
/ POWER BROOM #12
I ordered the hydraulic motor from Surplus Sales. They have stem casters with wheels also. I didn't see what I wanted for mine. I thought about welding a pipe T-connection to a bracket and use my mower stem caster wheels to save money.
Burden Sales Surplus Center
I got sick of the cold and moving more than normal amounts of snow so I decided to spend a couple months in Port Aransas, Texas. So, I cannot check the actual motor I ordered but it was about $100.
Dale
/ POWER BROOM
Dale,
Thanks for the help. I found a used broom on Ebay that was made for the Toro/Dingo
and already set up with wheels, hydraulics, etc. All I have to do now is change the mount to work on my tractor.
/ POWER BROOM #14
Tuning in on this one...
can anybody indicate the RPM the broom is turning (for which diameter of broom)
I am playing with the idea of attaching a walk behind rotovator gearbox (which can be converted to powerbroom by OEM accesoires) to my PTO output.
The gearbox is worm drive and set up appr 30/1, meaning a 3000RPM honda engine driving it makes the rotovator turn at 100 RPM.
With the PTO at 1000 RPM max that would leave me with 33 RPM for the broom and i wonder if this would be fast enough.
I am not in a hurry but it should also not become a joke.
pulleys can save the day but i dont know which target RPM I should aim for.
/ POWER BROOM
The 24" broom on the Toro/Dingo turns @ 150RPMs.
/ POWER BROOM #16
Dale
When you say 'paved with recycled asphalt' are you referring to loose, broken up asphalt? Or is it heated to a smooth surface?
Thanks.
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2015 BMW 328i Sedan (A59231)
2015 BMW 328i...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
