Power Beyond
/ Power Beyond #1
lugawl
I have a JD 2305 and it has the power beyond (PB) for the backhoe. I was thinking I could use the PB for a top-n-tilt or a grapple when backhoe isn't needed.
I want to know what you guys think is the best and smallest single spool OC valve for my purpose. I have been to Surplus Center but am not sure if I want a log splitter valve, seems it would work, or the other prince single spool valves???
I plan on mounting the valve at the base of the ROP on the angle brace, there are 2 holes already there for bolt-up.
Any input welcome!!
Thanks
/ Power Beyond #2
A log splitter valve operates more like an on/off switch, which would not be ideal for most applications. A spool valve will give you finer control. I think you would want at least a two spool valve. One spool for "top" and one spool for "tilt".
/ Power Beyond #3
This Cessna valve is a perfect fit. It is small, lightweight and compact and is rated at 5gpm. Many users have used this valve with great results.
/ Power Beyond #4
Never saw a log splitter valve that wasn't a spool valve. Never used one that couldn't be feathered, either. The one sided detent would be bothersome, though.
/ Power Beyond
The cessna valve looks great but the flow is slightly below the 2305s pumprate of 5.2 GPM. Is this a concern?
/ Power Beyond #6
Also the cessna valve does not say anything about load checks in the specs.
That would be important to me. Most other valves list this as a feature but this one does not. I do not know if that being left out of the description means it will not lock the cylinders but I am wondering.
Regards,
Mundy
/ Power Beyond #7
Look at the specs carefully, you will see that the 5.2 is the total, but the steering takes 2.3 GPM, leaving 2.9 GPM for the implements. This is probably done through a priority valve.
2305 Specs
Type Open Center
Pump Rated Output, gpm (L/min.) 5.2 (19.7)
Steering 2.3 (8.9)
Implement 2.9 (10.8)
Pump Type Gear
Maximum Operating Pressure (PSI) 1987
Draft Control Type Select Control
Remote Control Valves Available 2
/ Power Beyond #8
Regards,
Mundy
I would assume it does, but you could call them to verify, they are very helpful on the phone.
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
3096 (A63117)
3096 (A63117)
Unverferth Lift Assist Wheels (A65640)
Unverferth Lift...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
