Power beyond Valve, Some help Please
/ Power beyond Valve, Some help Please #1
Firefighter Kubota
Platinum Member
Seacoast NH
Kubota 7510
I'm looking to intall a power beyond / auxillary hydraulic lines on my Kubota 7510. for 2 purposes.
1) to controll the angl of my bucket mounted snow plow,
2) for my 3 point log splitter (has its own valve)
Can someone confirm that this TSC valve will do the work.
Tractor Supply Company - Directional Control Valve
Obviously I need a 2 position valve to swing the plow blade, but also need a continuous flow thru for the log splitter.
Any advice?
Thanks, in advance...
/ Power beyond Valve, Some help Please #2
That valve does NOT have a PB port, nor is it mentioned if it's available.
Are you going to plumb this from the PB connection on your FEL valve?
Hi kennyD,
yeah, sorry my title was confusing.. I'm looking to install this valve off my PB of my tractor - a rear remote, that will be used forward and rear with QD hoses...
/ Power beyond Valve, Some help Please #4
I am still not clear, you already have a PB connection at the rear>and want to just plug a valve in to operate your plow?
Or do you need to plumb everything?
I will be plumbing from scratch. I have the diaghrams.. and have check the other tractors at my dealer.
I originally was going to run a line off the PB to the rear with a return (like that found supplying a back hoe) for my splitter. (has it's own valve)
but decide I might as well put a control valve in as well, so I can use it for another implement / plow etc.
so I need a valve that serve as a flow thru for the splitter and act as a control valve...
make sense now?
/ Power beyond Valve, Some help Please #6
OK, I think I got it.
You would need a valve with a PB plug.
With the valve mounted, you would run a hose from the PB port on your FEL valve to the IN of the new valve, then on the PB port of the new valve, you could put a QD, with a hose running to wherever the PB from your FEL valve runs now. Then the OUT ports can be T'd to the existing valves OUT port for the return-to-tank.
To hook your splitter up, you could just undo the line on the PB port since it will have a QD-then insert your splitter in series with that line.
I would suggest the Prince SV series stack valves, that way you can always add a new valve section if you need to.
2009 IC Corporation School Bus, VIN # 4DRBUAAN19B694286 (A65563)
2009 IC...
Frontier Bale Spear (A65640)
Frontier Bale...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
CountyLine 7ft Cutting Harrow (A65579)
CountyLine 7ft...
