Power Beyond SCV "Burp" Noise
   / Power Beyond SCV "Burp" Noise #11
Where is the 3ph when this is happening? Is it happening while
the arms are up/ down/ or both?
I think both, but I am not sure. I will have to check.
Well the 3 point arms seem to be related. When the arms are down, I do not believe the valve jumps....it does in the raised position. And it also seems to do it when I raise the arms.
A month or so ago, the dealer had to come to get the air out of the system so the arms would raise high enough for the backhoe to get off (you take the load off the pins with the 3 pt).
Any ideas how to purge the air from the system once and for all?
   / Power Beyond SCV "Burp" Noise #14
It might be raising too high, and going into relief.
That adjustment is very tricky, so you can unpin
the hoe, and not go into relief..
I doubt it's air in the system.
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
INGERSOLL RAND INDUSTRIAL AIR COMPRESSOR (A54756)
INGERSOLL RAND...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
Agco 3pt. Disc Mower (A50775)
Agco 3pt. Disc...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
