Power Beyond Question
   / Power Beyond Question #1
gsdavis1
Cleveland, OHIO
John Deere 855
I have a John Deere 855. Instead of buying the Deere power beyond kit, I was thinking of just getting the diverter valve and plumbing the rest myself.
My question is...could I just take two lines right to a fender mounted valve and put quick connects on the valve?
Here is a link to the install of the deere kit with good pictures.
http://www.mytractorforum.com/showthread.php?p=1583786
Greg
   / Power Beyond Question #2
Yes, you only need to purchase the "plug"-the little set screw thing from JD, all the rest can be sourced locally or online. Lot's of guys have done this same thing...
Thanks. I have an extra 2 spool valve here at the house. Is there an easy way to tell if it is open center? Or does it matter.
   / Power Beyond Question #4
Oh yes, it DOES matter! You must have a OC valve. Air pressure is a good easy way to tell-hooks 100lbs of air to the IN or P port and see if it blows freely out of the OUT or T port while in neutral. Got a picture of part number of the valve?
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
