Power beyond port for LA513 loader
   / Power beyond port for LA513 loader #1
Goattownwoodcutter
'06 KUBOTA L3130GST
I'm in the process of converting our loader to QA. Will a 3rd function valve kit work or need to get diverter kit?:)
   / Power beyond port for LA513 loader #2
Getting a grapple, need the 3rd function for it.
   / Power beyond port for LA513 loader #4
Ahhh... that makes better sense. I feel like I've chimed in on this subject three times in the past week. Apparently, tis the season for 3rd function valves. I just finished my install on my L3200. I went with the Landpride kit from Messicks. Many folks like their WRLong kits from EverythingAttachments. Someone else also chimed in with the kits from Summit, which can be had on Amazon or direct. Sounds like you have your answer though. I'm no expert, but as far as I can gather, 3rd function is ideal, Diverter will work, you just won't have the ability to use all functions at the same time. Maybe I need to make a video of my install????
   / Power beyond port for LA513 loader #5
Yes 3rd function will work off the power beyond port. If it is an electric over hydraulic valve for third function, make sure it can handle the full back pressure of the system down stream. Most can but should be verified. Good luck!
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Informational Lot - Shipping (A53473)
Informational Lot...
FRIGIDAIRE 24,000 BUT WINDOW AC UNIT (A51248)
FRIGIDAIRE 24,000...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
