Power beyond kit installed on my 4120
   / Power beyond kit installed on my 4120
tschwerm, Just curious how you connected everything and what works and what does not work. Can you describe your complete flow path for the hyd from pump to tank. When you remove the log splitter, how are things connected?
Sorry for not replying sooner ..The power beyond is basically a coupling (male and female with w frame mounted female and the male is connected to a 2 foot hose...it loops high pressure through this hose... When I add the log splitter I uncoupled the power beyond hose and insert the two hoses from the log splitter into the power beyond circuit..then you have higher volume hydraulic flow at a low engine speed..
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A51039)
Kuhns AE10 Small...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A51039)
John Deere 752...
Caterpillar Front Glass (A50854)
Caterpillar Front...
