power beyond hook up.
/ power beyond hook up. #1
Suess
Minnesota
I finally got the SV series prince valves for rear remotes. How do you plum them into the tractor correctly? We have the 4 way valve on front. B7610 tractor. Thanks
/ power beyond hook up. #2
I don't believe the B7610 has the rear aux hydraulic block so you have got to connect into the loader valve. The easiest way is to disconnect the loader's power beyond hose from the front hydraulic block. Connect the hose from your SV valve's inlet port to this hose with the appropriate fitting(s) (or you can run a single hose). Connect the SV valve's power beyond port to the front hydraulic block. The outlet port of the SV valve must be teed into the loader valve's return to tank port. This is easiest done at the transmission. You are now ready to use your SV valve.
Thanks,
I'm going to try and get it working in the morning. I hope any way. Thanks again.
One more question. Did you have to have a special fitting for the power beyond on the outlet section? The one they sent me has the port but the sheet that came along shows a special fitting with what appears to be a o ring on the end. What I got just has a plug in the port. My first thought was that was for closed center systems but now I wonder. The sheet just states (plug power beyond) or something like that. I did order outlet section with power beyond for open center. Or at least I thought i did. I never got to the point of hooking it up today. Just got the bracket built. with no room on the B7610 I had to go out side the rops, on the right side. Thanks for the help,
/ power beyond hook up. #5
Go to the Prince web site and download the parts manual for the SV valve. You can find it HERE. Page 23 will show you what you want to know.
If you ordered the SVE22 option for the outlet section you should have gotten the power beyond plug (item #4).
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
3 BottomPlow (A62613)
2017 John Deere 6110M (A64126)
2017 John Deere...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
Danuser 3 Point Post Auger (A65640)
Danuser 3 Point...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
