Power Beyond Flow and Pressure???
   / Power Beyond Flow and Pressure???
The new thread will be in attachments....
-J.
   / Power Beyond Flow and Pressure??? #12
Wow, nice discussion.......!!
Thanks for the info guys. I've found Prince PTO pumps that will attach right up and provide what I think is more than enough flow and pressurre.
I'm gonna start a new thread with some other Q's.
Thanks again,
-Jer.
I see you list a hydraulic drive front mount snowblower in your 1st post list. That will have the largest demand of the tools you mention. A PTO pump is the only real option for that use. Carefully size all the components.
   / Power Beyond Flow and Pressure??? #13
Good info, here.
Can generally learn something or two on TBN - and that's one of the major reasons I'm always checkin' in on these forums..
Thanks.
AKfish
   / Power Beyond Flow and Pressure??? #14
I use a Prince PTO pump with a loader mounted snowblower. I works well.
Consider a forward-neutral-reverse hydraulic valve to help in clearing jammed sticks, stones... Also have a reservoir sized in gallons roughly equal the pumps flow rate in gallons/minute. I have 3/4" lines for the 21 GPM pump...adequate but maybe barely.
24in Digging Tooth Bucket Excavator Attachment (A55973)
24in Digging Tooth...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
