power beyond again
   / power beyond again #11
If you are asking about the length of the top link cylinder just measure the extended and retracted length of whatever you have on there now and go over to the CCM website and order one that closely matches the difference between your measurements. Buying from either Kubota or MF will give you cylinders without check valves which will translate to inferior and disappionting performance.
yes that was the question what diameter cyl would you use the one on the 1552 at the dealer is i think 3" i got the gear more # for it but the kubota dealer said it is a bad # ...i know you all suggest the check valve cyl but i think i will go with the gearmore one all the dlrs that i talk to here say they have never had a problem,maybe if the kubota dlr can't get me the right size i will go with the check valve thanks for the help jon
TANK MANIFOLD (A55745)
Hydraulic Dingo Trencher Attachment (A55272)
Hydraulic Dingo...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2003 Freightliner FLD 120 Columbia (A56436)
2003 Freightliner...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
12' Container W/Side Door and Window (A57149)
12' Container...
