power angle dozer blade problem
/ power angle dozer blade problem #11
If those are DA cyl, shouldn't the hose connect the base on one cyl, and the rod end on the other cyl. I know the volume is not equal.
One cyl should be extending, and the other retracting.
That won't work because the displacement is different in the rod end and the base end.
The two cylinders in series act like one cylinder. "A" to base of cylinder # 1 and "B" to the base of cylinder #2... cross over connecting the rod ends of the two cylinders
  • hyd.pdf
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
Bobcat T590 (A53317)
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
24in Hydraulic Auger Skid Steer Attachment (A59228)
24in Hydraulic...
