Pouring steps down to the creek/swimming hole...nope, never done it before!
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #51
2' wide rope staircase? Anchor top rung to ground, roll up when done. Alternatively, anchor top end to back of a truck/tractor.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #52
The concrete will not likely work against moving water. Drive piles or build the stairs with 2x6 planks on the bottom side and skid them to high ground in the Fall.
Have you noticed all of the concrete structures on streams that have lasted for decades
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #53
I have. And I've also noticed hundreds of dilapidated concrete staircases and retaining walls on riverbanks on my many canoe/boat/float/fishing trips in my life. Both private and municipally owned. Mother nature doesn't care.
The OP's mention of stairs to a creek, then pictures of what can occasionally happen with flooding makes me (and probably a few others) wonder if a professional engineer might be of assistance?
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #54
State road engineers designed the bridge over the local river about 10 years ago here. The bridge got built, and shortly thereafter, the state troopers blocked it off to traffic after the engineers figured out that the unusual stress cracks in the concrete decking were because they didn't build the supporting piers strongly enough. So they spent almost the same amount of money as it took to build the bridge building support walls under the piers.
Either that, or they'll so engineer the thing that you can't afford to build it. Or they'll tell you to get some environmental permits.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #55
Can you tether a boat with folding steps?
Suggestions kinda got quiet here after you posted this picture.
What....do they think I am harboring the Atlantis civilization under all that H2o?
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #58
Didn’t know that the Mississippi river went through East TN.
According to the locals, the worst flood was spring 1993. It followed a massive blizzard that dropped up to 5' of snow. It would have put another foot of water over that pic of the pasture from the road.
OK, maybe I am wrong, but I do not see the rip rap moving around from flooding. The stairwell will be low profile and tucked inside and anchored to said rip rap. They will also be behind(from the direct current) and in voids created by the pigs and the weir. This is about a thousand dollar investment and some time, so I think I am going to throw the dice.
Maybe I screwd up with the rip rap, and should have done what NOLA did in the 30's on the shore of Lake Pontchartrain:
Lately, I am not impressed with ANY pressure treated lumber. I swear, I think they spray it with iced tea and ship it out. The West deck of the house is 11 years old, & 10' off the ground....it is now rotting and will require a complete re-do(with composite). My walk bridge over the creek that is 12 years old...rotten boards. I have 6x6 PT posts in ground for less than 10 years that are rotted off at the ground....I am done with PT wood for deck/stairs/bridges.
Another drawback is PT decks and steps are slick as Owl snot. I did consider a swing up staircase, but really want a 'once and forget it' job. We can get weather moving so fast and unexpected, there is a good chance no one would be able to raise them in time.
   / Pouring steps down to the creek/swimming hole...nope, never done it before! #60
PT will be slick as snot when wet and someone is likely to fall.
Concrete can be finished to not be slick and will outlast PT by eons unless it washes away. You can reduce the odds of it washing by trying to place it and form it so water flows past it instead of pushing against it.
Since there is evidently no bedrock, I wonder if setting a couple of post piers at the bottom might be an option or if you intentionally build the upper portion to be permanent, but build the lower portion as sort of sacrificial and replaceable?
Or do you somehow sink a a largeish sonotube and pour concrete in it for the base?
Caterpillar 725 Off-Road Dump Truck (A57453)
Caterpillar 725...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
(2) 225/75D15 TIRES W/ 5 LUG RIMS (A52708)
(2) 225/75D15...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A58017)
2019 PETERBILT 579...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2012 LAND ROVER Range Rover SUV (A56859)
2012 LAND ROVER...
