Pouring concrete under water
   / Pouring concrete under water #1
AlbertC
Perry, GA
New holland 3930
I built a wood duck house to go beside my fishpond. I dug the hole where I want to put the post but before I could get the post installed we got 3" of rain and now my hole is underwater.
I have heard that you can pour concrete underwater but I'm not sure how to do this. Tried dipping the water out of the hole but it filled back up quicker than I could dip it out. If I mix the concrete and pour it in the 36" deep hole that I have dug the concrete will dissolve before it gets to the bottom of the hole.
Any ideas how to do this. I don't want to dig another hole further away from the edge because I want to put the duck house where I dug the original hole. Also don't want to wait till next summer to put up the duck house.
I thought about putting a garbage bag in the hole then putting in the post and then pouring the mixed concrete in the bag which will force the water out of the hole.
Any other ideas appreciated.
Post Extras:
   / Pouring concrete under water #2
You could use a sonotube to deliver the concrete to the bottom unadulterated and it will force the water out similar to a "sock" we would use on a concrete bucket to deliver cement to the bottom of a flooded excavation. On a big job, We sometimes do the same with the cement pump hose to the bottom
   / Pouring concrete under water #3
Why couldn't you pour dry redi-mix in the hole?
I think if I were to just pour it in dry the rocks would sink to the bottom of the hole and most of the dry would float to the top and I would not get a good pour. The mix would be off. But I don't know if this is the case or not. Has anyone ever just poured the dry mix in the hole. I can see where thi might not be a proble if the hole was not very deep, but this hole is 36" deep.
If I put a sono tube in the hole it will just be full of water also. Wouldn't I have to try to pump the water out of the tube.
   / Pouring concrete under water #6
I'm picturing the duck house like a fence post with a box on it. Maybe it is more substantial than that.
I wouldn't pour dry mix in water filled hole for structure like deck or pole barn. I have used it for fence posts including those used to support farm gates. I haven't had problem with gate posts sagging or leaning.
   / Pouring concrete under water #7
Concrete curing is a chemical process. If you pre-mix properly, there should be no "dry" . Mix and pour into hole, and you should be fine.
   / Pouring concrete under water #8
You need to use a method called "tremie"
The tremie concrete placement method uses a pipe, through which concrete is placed below water level. The lower end of the pipe is kept immersed in fresh concrete so that the rising concrete from the bottom displaces the water without washing out the cement content.
You can do a search and get a good idea how to do it
   / Pouring concrete under water #10
properly mixed concrete will displace the water .
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52128)
2024 BCL...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2018 GENIE...
2008 Ford F-250 (A52128)
2008 Ford F-250...
