OP
Indygunworks
I could still do a square, and just use the smaller sonotube for the inside to keep it open... BUT, I don't see the point. I am considering now making a paper template of the bottom that once the concrete sets up just a bit I can insert stainless threaded rod into the pattern. that would allow the concrete to be 3 -6 inch's below the top of the well casing leaving room for the cap. I could put some nuts and washers on the threaded rod and put the pump base over that. It would elevate the pitcher pump but still allow normal use. If there are ever any issues and the bolts are in the way I could double nut them and back them out w/ a wrench.
The well cap options you list would work well for an uplift pump, but that's out of the budget. I plan on an installation similar to this, except with the well casing being slightly above the concrete not below.
Lee Valley Tools - Installing and Using the Pitcher Pump
