Leonz, you're not entirely correct. Indirect diesels most certainly have injectors.
the duetz engines most certainly do not, they have nozzles
The fuel to a direct injected engine is pressurized in a 'common rail' at a very high pressure.
yes.
Each injector is told when to fire directly into the cylinder either electronically, or in some cases, it is electronically controlled but hydraulically actuated (caterpillar).
The Bosch and Nippondenzo are strictly mechanical.
There are also usually multiple injection events per stroke.
If that happened the engine would stop
The firing order determines firing sequences with the fuel delivered to the specific cylinder in one burst with the injection pump which in the Duetz and Kubota engines are lined up with the injection pump to properly feed fule at the right time to the correct cylinder
In other words, a small pilot injection to get the fire started, followed by a large injection to get the power, followed by another smaller injection to let the fire go out slowly...all in milliseconds. This is why the new common rail engines are so smooth and quiet and do not have that diesel rattle.
the engines are recieving the proper amount of fule for firing versus what is happening to the BX models and others to secure the EPA blessings
An indirectly injected engine has a mechanically driven lift pump (jerk pump) which feeds injectors via individual fuel lines.
yes the diaphram pump is common on the Duetz and others
Each injector is timed (usually mechanically)
Via the springs and stops in the fuel side of the injection pump.
No precombustion chamber in the Duetz motors; The pistons have a 3 leaf clover in the larger air cooled engines and the smaller ones.
and fires into a precombustion chamber above the actual cylinder.
The diesel would never work as the fuel is compressed to the point that the metered amount of fuel is compressed to the point the limited volume of fuel physically explodes at the molecular level and a precombustion chamber would never work on a diesel anyway for the above reason.
There's a lot more to it than this crude summary, but both indirect and direct injection diesels have injectors.
