boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
Accidentally posted this in regional forum, but meant to post here, so I reposted. Anybody ever poured a foundation without forms? Not just the footing. The entire footing and wall without forms. Free pour directly in the trench. Getting ready to build small barn (20x24) for equipment storage and was thinking would be faster and cheaper to skip the forms. Have access to excavator with 12" bucket and can trench it myself. I remember a post years ago where tbn'r did this for a garage. Oh yeah, I'm in Connecticut, so I have to go 48" down. And I want to put slab inside after foundation poured. Anybody ever done this?
sounds like overkill.
there are many "slabs poured on grade" basically concrete poured on top of the ground. no walls / supports down into the ground. most likely top soil removed, and back filled with drainage rock" and then concrete poured. at most... what is called a footer is done around the outside perimeter of the concrete. to help the edges stay together. and keep from cracking.
i have 3 large pours like above... 1 large pour outside (used to be feed lot for cattle.), and then i want to say 40x60 shed 2/3rds of it is concrete just poured on the ground. and then the other shed 30x60 i want to say there is 30 by 15 foot slab poured inside of it.
contact your local concrete pourers / finishers / crews. they will know your local codes / weather conditions and suggest something.
pay for a "good finisher" a bad finisher can make or break a concrete floor pour. as being to rough to lines in it, to little waves in it, to high / low spots in the floor. a good finisher has the tools and more so ability to control things to get correct wanted outcome.
