Poulan Wild Thing Starting Problem
   / Poulan Wild Thing Starting Problem
As I mentioned before, I sprayed a shot of ether into the carb and gave it a few pulls. No pop. I removed the plug and set it right next to the plug hole and on the first pull ether shot out of the plug hole and ignited instantly in the open air. Instantly. I repeated this several times and it was always the same.
/QUOTE]
All I'm saying here is the path for air to the cylinder will be open. The use of ether is entirely up to the OP.:)
I have had occasions where holding the trigger down will allow a saw to start.:D
Moss, did the fellow who borred the saw let it sit for so long cause it was cutting real slow??:confused::confused::laughing:
Yeah, I'll try the full trigger with a shot of ether next. I don't have a compression gauge. I know its harder to pull with the plug in and spins like a top with the plug out.
Here's the deal on the saw... it involves my wife's father, brother, a really nice Stihl saw that got borrowed and never returned for a really long time, a lame attempt at reparations, another borrowed saw, another really long time, another Stihl saw and the return of the lame reparation that we are discussing here! :laughing: Its soap opera quality. :confused2:
   / Poulan Wild Thing Starting Problem #22
About 8 years ago I gave my son a small McCullar saw and he left it in my barn for the last 6 or more years. Not long ago I went and got it and the tanks were dry. I poured about 4 tablespoonsful of seafoam in it and pulled it thru and let it set for about an hour and a half. Then filled it with gas, choked it and it fired right up. That seafoam is great stuff. Speedy2
   / Poulan Wild Thing Starting Problem #23
Without having some basic diagnostic tools such as a compression gauge, your going to be chasing your tail.
Hence my original suggestion of throwing it out ;)
You got spark. You had fuel (ether). That only leaves compression, at least for now. A stuck ring or gouged cylinder are options. Id bet its down in compression if i was to guess, but without a gauge to confirm, who knows?
Yar. How much does a gauge cost anyway?
   / Poulan Wild Thing Starting Problem #26
HI All,
Just joined this interesting site. As of a few hours ago I have a similar problem with a Poulan saw except that our's is about 2 years old & was running fine when it just quit -dead. Now I've done quite a lot of work on small 2 strokes & frankly was pessimestic that there would be an easy fix. Nonetheless, we checked spark & that was fine, dumped the gas into a pail but no sign of water, put in fresh anyway & disassembled & cleaned out carb (no problems). Tomorrow I will check compression but I want to point out that on quite a number of 2 strokes that simply will not start or even bark, I have found that there's scoring on the cylinder wall between the intake port & the crankcase. When this happens you can still get a decent compression reading at the spark plug but the crank cases blows back thru the port so you won't compress the next cycle's charge. In these cases, you will never find a wet spark plug.
Now my question/statement is that this seems especially common on the cheaper brands - We're still running a couple of really old Jonsereds (1970's) & an old beat-up Oregon Farmer, so why does a 2 year old Poulan suddenly give-up?
B Sea in BC
   / Poulan Wild Thing Starting Problem #27
try a different spark plug i just fixed one doing the same thing plenty of spark and fuel but no fire changed the plug took right off
   / Poulan Wild Thing Starting Problem #28
The Poulan has died b/c as another poster mentioned earlier the piston/cylinder became scored by the exhaust port. No compression = No Go.
So I ponder again, why a 2 year old Poulan becomes a landfill donation, yet my ancient Oregon Farmer, Homelite Xl12 & even older Jonsered keep on going? Did the old ones have a steel cylinder sleeve? We've been using these saws for a long time & we are careful to use the right 2-stoke oil/mix so I am curious as to why, that Poulan just suddenly got scored up.
B Sea in snowy BC
   / Poulan Wild Thing Starting Problem #29
I owned one of these briefly. It NEVER ran well...just wouldn't get on the pipe and stalled EVERY time I tried to cut with it. I think it had more rotations of the crankshaft from trying to start it than actually running. I'd have been better off if I'd pulled the spark plug, rested it on a branch and pulled a lot. I felt great throwing it in the trash and better when I replaced it with a Stihl.
   / Poulan Wild Thing Starting Problem #30
Every cheapie poulan that is brought to me after someone buys it with running problems is usually so lean from factory (can you say EPA) they are set for failure from the get go. Lean = burning up. I re-set carbs and 30 min muffler mod and they seem to last forever. There is one out there for I bet 10+ years now.
Guys just need to learn how to tune carbs and sharpen chain and listen to the motors on all saws etc IMHO and not just try to run them straight from the box. Failure is only a short run away if you do not learn. I have seen MS660 burned up from being on lean side and D.A. running super dull chain for extended cuts and that is a $1000 saw.
Lot of the saw failures I have seen is usually the owners fault not knowing how to tune and do general maintenance on a chainsaw. It's to easy people learn and save yourself $60 a hour at the dealers. Look at it as paying yourself.
Oh and if you are one of those guys that pays $99-$129 for a cheapie saw, why do you expect $300 saw outcome. You get what you pay for. You can make it better on your own if you do go cheap route.
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2014 Ford F-250 Crew Cab 4X4 Pickup Truck (A55973)
2014 Ford F-250...
ROBIN AIR 34788NI A/C RECOVERY MACHINE (A58214)
ROBIN AIR 34788NI...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
Deere 350G LC (A53317)
